Using 2 inputs to Clock MUX doesn't result in correct answer
Thank you for using Intel's support services. Can you provide your project so that we can help you locate the problem?
Thanks & Regards,
Tingjiang
Unfortunately I cannot provide you the project because of company policy. Here are the details:
clkin_50_bot pin_AP20
hsma_clk_in0 pin_AL5
PLL configured in the Platform Designer with the following behavior:
refclk1 = clkin_50_bot, passes through Clock Source IP
refclk = hsma_clk_in0, passes through Clock Source IP
Configured to use Manual Clock Switchover
PLL creates:
outclk0 = 26MHz
outclk1 = 104MHz
outclk2 = 520MHz
Once I have created this design through compile I use the Netlist View -> Post Fitter to get the following schematic view:
As you can see only one of the input clocks? Also notice that I don't have the manual clock switching output or the output which tells me which clock is being used. The only "warning" I receive is the following from platform designer:
So this should be a pretty easy model to make to reproduce this issue. Yes I am aware there is another warning about two frequencies being different. They are 50MHz and 52MHz which are within the 20% requirement. I have also tried making the frequency's the same and get the same refclk1 error.
Any ideas?
TomT...
