ThomasTessier
3 years agoUsing 2 inputs to Clock MUX doesn't result in correct answer
I have a design were I am trying to use the Input Clock MUX to Switch between two input pin clock ports. The PLLs are in platform designer and I get the following warning:
Warning: test_system_qsy...
KennyT_altera
3 years agoKindly note that there will be some slowness on the first reply due to the public holiday, we will get back to you as soon as possible.
