15 years agoUseing the TimeQuest timing analysis to analyze the PLL
In the process of learining the TimeQuest timing analysis,I used the TimeQuest timing analysis to analyze the PLL,but there are some timing requirements not met,I don't know what went wrong.
There are two outputs from the PLL,the phase and frequency of C0 remain unchanged relative to the CLK,the clock multiply factor of the C1 is 2,and the phase of C1 is -63.The report setup summary shows that the C1's slack is negative,I think the PLL should be able to achieve that kind of design,maybe there is something wrong with me. Is there anyone can help me? thank you in advance!
