Fromhell777
5 years agoUse correct latch timing during place and route optimisation
As I understood the timing analyser treats level-sensitive latches similar to registers. When looking into the documentation the only option that you can execute to have a correct timing analysis of ...
Fromhell777
5 years agoHere is a simple example.
I created a circuit where data goes from a negedge flipflop, to a negative (open-low), level-sensitive latch, to a posedge flipflop.
In the timing analyser you can see that the setup time from the negedge flipflop to the negative (open-low), level-sensitive latch is as good as nothing. I expect that the setup time should be a bit less than half the clock period. Even with the "-dynamic_borrow" option I don't see anything change which I found strange.
Can you explain this?
This could have a lot of impact on the rest of the timing when the tool tries to fix this with clock skewing
Fromhell777
5 years agoDid you already have time to look into this?
