14 years agoJust a note on how I solved this problem..
It was the driver that came with 11.1sp2... I had the same problem above, and tried all the different suggestions: - using older DLLs - downloading the '64bit version' (I never found a true 64bit version) - using v10.0 programmer - re-installing the driver - checking that other applications weren't trying to use port 1309 So I eventually just downloaded the USBBlaster driver zip from Altera website. <url deleted because I don't have url posting privileges - you can find it by googling "usbblaster driver windows 7"> and reinstalled the driver with those drivers and it's working now. So if you have 11.1sp2, that might be your problem.
