14 years agoUSB Blaster won't program via MV interface?
I can program the old UP-2 (ByteBlaster II) within WIN7 and a USB Blaster but can't program a (EPM7064SLC44) via a simple MV hardware buffer (HC244) interface?? Is the USB Blaster NOT ByteBla...
14 years agoHi, thanks for your response. No schematic although, I did some reverse engineering yesterday to find out that the interface is not a true JTAG interface even though the connector on the CPLD board is a JTAG connector. The board and the (special) parallel cable have to be used together to program the device. I'll have to modify the boards to program via USB Blaster. I'm a little worried about connecting directly to CPLD JTAG pins because all interfaces I've seen include a buffer in between?
