14 years agoUSB Blaster won't program via MV interface?
I can program the old UP-2 (ByteBlaster II) within WIN7 and a USB Blaster but can't program a (EPM7064SLC44) via a simple MV hardware buffer (HC244) interface?? Is the USB Blaster NOT ByteBla...
14 years agoThere's apparently a fault in your hardware design. You should show a schematic. Why did you place the HC244 buffer at all? Regularly, USB Blaster would connect to the MAX7000S JTAG pins directly.
