10 years agoUSB Blaster remote setup
I'm trying to remotely connect to the jtag server to program a DE-5 board.
Netstat in the server shows me this tcp 0 0 *:1309 *:* LISTEN But when I run the jtagconfig --addserver server_name password in the local machine it prompts nothing but when I run jtagconfig later, it shows me Remote server server_name: Unable to connect. I ran jtag --foreground --debug on n the local machine and got the follwing output madushan@electron:~$ jtagd --foreground --debug JTAG daemon started Using config file /etc/jtagd/jtagd.conf Remote JTAG permitted when password set No USB device change detection because libudev.so.0 not found Can't bind to TCP port 1309 - exiting once again tried a telnet and result, madushan@electron:~$ telnet server_name 1309 Trying 129.252.131.52... Connected to server_name. Escape character is '^]'. Connection closed by foreign host. I would really appreciate somebody could help me with this. Thanks2 Replies
- CapChimiChangas
First, you are missing libudev and libusb in your system.
Also : "Remote JTAG permitted when password set "
You need to set a password.
- CapChimiChangas
One more thing if your network is secure and your lab has no external access, do the following:
AS root on the machine with access to your device, run
jtagd
then immediately
jtaconfig --enable-remote password_of_your_choice
You can now use Quartus to connect remotely and program and debug via JTAG on your device.
