Let me start by saying…
I am not one of these people that “has to” run the
latest OS, but I wanted to run a 64 bit OS to try and
speed up the very long compile times I get when I have
a nearly full Cyclone3. 64 bit Quartus made claims of
being better, and I figure that the 4G (3G really) limit
of 32bit x86 was possibly a speed killer for Quartus.
I was assured by the Altera tech sales team that
Quartus 64 bit is the way to the future, so I bit…
Anway…..
----Altera tech support staff: This you really ----
----need to try yourselves to see the problem. ----
Go get a new win7 machine, that has never
had Quartus installed on it, and plug in
a usb-blaster. Be sure that this is a “fresh”
computer – NOT a VM, NOT a computer that
someone un-installed Quartus on, not a computer
that was running anything Altera – ever.
Get a machine that truly has never had
any Altera stuff on it. (because stuff left in the
driver cache and the registry may give you
artificially good results)
Then the fun begins. Go download the Q11.x
programming software and install it. This will make
it so that you can have the "latest" device drivers
for the USBBlaster in your Quartus directory.
Then plug in your USBBlaster. Windoze will do the
“ding dong” and start looking for the driver on the
internet. (FAIL!) – you might want to fix this too
while you are at it – but lets not get ahead of
ourselves just yet. Windoze will not find the drivers,
and will ask you to look for it on your computer.
(or it may just fail out – I forgot / suppressed the
awful memory of this). Windows will then make the
“Something bad-usb wise just happened “d-d-dong”
sound. (It is OK at this point to say a few of your
favorite expletives)
Using the control panel, open systemàDevice
manager. The usb-blaster will be in there with a
yellow mark next to it. Click on it and “update”
the driver. Use the Altera provided drivers in
c:\altera\11.3\programmer\drivers\ (or whatever
the path is, I am doing this from memory now)
Windoze will try and install the drivers and then
give you a bunch of useless errors, and not get
the USBBlaster to a useful sate.
such errors include:
"Cant install device, the service name is already in use"
"Windows cannot find the driver for your device"
"Error 28"
The harder you try to get it to work, the more
the errors you will get.
You will really start to hate the “d-d-dong”
“something bad USB just happened” Windoze sound.
Get used to it. You are going to hear it allot.
Eventually, you will install and uninstall many
versions of USBBlaster drivers. Finally you will find
this forum, read this thread, and install the 7.2 drivers.
You will have to agree that you are installing an
unsigned driver. At this point you will try anything,
and you will be rewarded for your bold and courageous
choice. 60 or so seconds later you will hear “Ding-Dong”
from Windoze, indicating that (finally) something good
usb-wise just happened! Yay! You will then have a
working USBBlaster!
I am very frustrated because this is the 3rd time
I have needed to install the USBBlaster on a 64 bit
machine (ranging from 2 years ago with winXP 64)
I had a BUNCH of tech support calls to 1-800-800-epld
(or whatever the 800 help number is/was) and I had
also had a lot of E-mail correspondence with the
Altera tech support. In that time, no one at altera
had any useful suggestions. My local Arrow FAE: FAIL.
He never once returned ANY of my calls to him.
(I started using Altera products 15 years ago,
before he had graduated from junior high. I guess
I am just not that important of a customer to him.)
Anyway, all I got from email and 800 support was
stupid novice suggestions like "use a shorter usb
cable" and "shorten the length of the 10-pin JTAG
connector" - as well as "reboot the PC" and “un
install and re install Quartus and the drivers"
I will give the tech support line some slack, as this
was my experience 2 years ago with winXP 64, but I was
greeted with difficulties like this on my first win7 install,
(about 1 year ago ) and I somehow got it working. I
am thoroughly disappointed with my latest experience
2 days ago, where I had to install the 7.2 drivers.
At first I was willing to blame myself, but this is the
3rd troublesome 64 bit install I have had with usbblasters,
across 3 different computers, 3 brands of computer, and
with multiple usb-blaster cables. I now see this as an
Altera configuration management issue. Someone at altera
needs to repeat my experiments, and try and install a
usb-blaster on a FRESH 64 bit win7 computer. I bet
after that the next version of quartus will then get the
7.2 "right" drivers.
The thing is, the usbblaster uses the FTDI USB bridge.
FTDI is easy to work with, (I use them in my own designs)
and has supported 64 bit windows for years. Hell, Altera,
you had this working in version 7.2! just carry that over.
OK sorry for the second rant..
---Lou
