Hi there,
Same problem with Byteblaster...
I have tryed Wasabi_rice's driver on Win7 64-bit and it did not work (see message in attachment).
Does anyone have the old drivers (Quartus 7) that are supposed to work with Win7 64bit, having disabled driver sign check at boot time? If so, would you please share them on this forum? Thanks.
Cheers,
C.
--- Quote Start ---
Sup all,
I am running win7 x64 here. Here is a modified USB blaster driver I came up with. It works 100% as I tested on several machines. Hopefully this helps.
Cheers
Howard
--- Quote End ---
