Hi James,
--- Quote Start ---
I am not exactly sure which device is being used (FT2232 or FT232R for example) but many of the Terasic boards are FTDI controller + Max II CPLD for the on board USB blaster.
--- Quote End ---
The on-board USB-Blasters are FT245B+MAX II. The BeMicro-SDK uses an FT245R (which has an internal EEPROM).
--- Quote Start ---
Interestingly enough, the schematics for the DE-Nano, for example, do not show the circuit in schematic detail. Only a higher level block diagram is shown. From what I have looked at on the Terasic dev boards, this is generally true, as well as the recent and new Altera dev boards.
--- Quote End ---
The schematic is not really that exciting. Its just the FT245R in asynchronous FIFO mode connected to the MAX II :)
I've uploaded the BeMicro-SDK schematic, it shows the USB-Blaster circuit. Not very enlightening is it?
What is more important is the USB-Blaster protocol. That was reverse-engineered and published a while ago by Kawk
http://sourceforge.net/apps/mediawiki/urjtag/index.php?title=cable_altera_usb-blaster --- Quote Start ---
The frustrating part to me is the lack of transparency with a proven solution for this approach.
--- Quote End ---
Yes, it bugs me too. I'm working on a clone ... when it works, I'll write up a tutorial.
The latest FTDI direct access driver allow you to access a USB-Blaster ... I'll also write that up shortly.
Cheers,
Dave
