14 years agoUSB-Blaster not recognized
Why is my USB Blaster download cable does not recognized
with QuartusII 11.1 sp2, WIN7 64bit. Drivers installed correctly.6 Replies
The solution is here:
http://www.altera.com/support/kdb/solutions/rd03062012_414.html Cheers, Dave - Altera_Forum
Thankyou.
Cleared. Lee - Altera_Forum
Could you please help me about USB Blaster Cable on Windows 10. Win10 can recognized USB Blaster by hardware but no driver installed. Does USB Blaster cabe not have win10 driver?
In device manager, find the USB blaster, then right click on it, select "Update Driver". Then select to manually specify folder and point it to: C:\altera\<version>\quartus\drivers. Make sure to select the box to search subfolders.
I very very appreciate you. I go to ALTERA file folder for driver then install it.
and also, I can program the FPGA. Again thank you. - Altera_Forum
TDO always stuck at 0 error
We have a USB Blaster Rev C. JTAG Programmer whenever we are trying to detect the target device using UrJTAG Shell It is displaying the same error "TDO always stuck at 0" We have checked the following in an oscilloscope 1. TCK- We can observe for 1 second and after its being turned off similar is the case for TMS & TDI 2. TMS 3. TDI What could be the possible problem?? Awaiting for some reply Thank you
