10 years agoUSB Blaster JTAG pinning on board
Hi community, in the UG-01150 PDF "USB-Blaster II Download Cable Specifications" on page 2-4 table 2-2 there is a signal name I can't find on MAX10 device. The name is PROC_RST. Is this pin ...
10 years ago --- Quote Start --- Reading the specification thoroughly tells you that the signal is for hard processor reset. Hardly used with MAX10. --- Quote End --- Hi FvM, thank you for your reply. I didn't strapped the pin to the JTAG connector, but strapped him on another connector, just in case that it will be probably used. Thank you for your help. Have a nice day. Regards Jérôme
