USB-Blaster II malfunction
for me it is exactly the same trouble that Frank described.
With Blaster II or III we get the same results and we can't use them really :-/
Thanks in advance,
Taro
Hi Frank,
Thank you for the additional information, and I apologize that the previous steps did not resolve the issue.
Because the original USB-Blaster and Terasic cable work on this same board, the evaluation kit itself is not the primary suspect. To determine whether the affected cables should be evaluated for RMA, could you please provide:
- How many USB-Blaster II and USB-Blaster III cables are affected?
- The serial number of each affected cable.
- Have these cables been tested on another known-good FPGA board? If so, please provide the board or device and the result.
- Does .sof configuration succeed reliably at 6 MHz, or does only .pof programming fail?
- The complete Quartus Prime Standard version and build number, plus the Programmer log from one failure.
If possible, please perform this cross-test at 6 MHz:
- Affected USB-Blaster II or III on another known-good FPGA board.
- Known-good USB-Blaster or Terasic cable on the same MAX 10 board, which you have already confirmed works.
If the affected cables fail on multiple known-good boards, we may evaluate this for RMA. If they fail only with this MAX 10 kit, we will treat it as a cable and board compatibility issue and escalate it accordingly.
Fakhrul
- FrankK1 month ago
Hello Fakhrul,
Please find my answers below:
1. We have one USB-Blaster II cable and one USB-Blaster III cable. Both are affected.
2. USB-Blaster II serial number: UBII-000012141
USB-Blaster III serial number: UB30045463. We initially tested both cables with our own hardware, which also uses a 10M08SA device. To rule out an issue with our design, we repeated the tests using the official Altera evaluation board.
4. With the clock fixed at 6 MHz, both SOF and POF files download successfully on our hardware and on the Altera evaluation board.
5. Quartus Prime Version 25.1std.0 Build 1129 10/21/2025 SC Lite Edition
- FakhrulA_altera1 month ago
Hi Frank,
Thank you for the test results. Both cables program successfully at 6 MHz on your 10M08SA hardware and on the Altera evaluation kit, so the next step is to confirm that this setting remains stable during GUI programming.
Please run the following test:
1- Close the Quartus Prime Programmer.
2- Set and confirm the clock before opening the Programmer:jtagconfig --setparam 1 JtagClockAutoAdjust 0
jtagconfig --setparam 1 JtagClock 6M
jtagconfig --getparam 1 JtagClockAutoAdjust
jtagconfig --getparam 1 JtagClock3- Open the Programmer and program the .pof five times without changing the Hardware Setup frequency.
4- If a run fails, run jtagconfig --getparam 1 JtagClock immediately and record the value.Please send the jtagconfig --getparam results and the number of successful attempts out of five. If all five succeed while the clock remains at 6 MHz, this setting is the recommended operating condition. The supported frequencies are 24, 16, and 6 MHz, as described in Changing the USB-Blaster II Clock Frequency.
Thank you for your cooperation.
Fakhrul- FrankK1 month ago
Hello Fakhrul,
I've carried out the test procedure you specified.The settings for ClockAutoAdjust and Clock Frequency were correctly transferred and applied by the JTAG server. This was verified by reading back the parameters using “jtagconfig –getparam”.
I successfully programmed the target device five times in a row at each of the following JTAG clock frequencies:
6 MHz
4 MHzAccording to the USB Blaster II cable specification, JTAG clock frequencies below 6 MHz should also be supported. However, every attempt to set a frequency below 4 MHz failed with the error message “Can’t access JTAG chain, Operation failed”.
I measured the JTAG TCK signal and confirmed that its frequency matched the value previously set using jtagconfig --setparam 1 JtagClock (e.g. 400k) . However, communication failed.
Best regards
Frank
