USB-Blaster II malfunction
Dear Fakhrul,
thanks for your reply.
At first I need to rephrase my previous statements. Programming the pof-file with quartus_pgm is not always successful. From time to time it also fails. But the QUARTUS programmer GUI always fails to flash the FPGA.
Please try the following:
- Continue using 6 MHz with automatic clock adjustment disabled.
- Close the Programmer, restart the JTAG server, and reconnect the USB-Blaster II.
> Done, but this has no effect to the error mode - Connect the cable directly to the PC and temporarily disconnect other USB-UART or FTDI devices.
> Done, but this has no effect to the error mode - Ensure the USB-Blaster II driver comes from the Quartus Prime Standard Edition 25.1 installation and that drivers from different releases are not mixed.
You may continue using quartus_pgm as a temporary workaround.
> Since quartus_pgm is also unreliable, the issue remains unresolved, and I still do not have a functional workaround. I also installed the standalone Programmer application on several clean PCs and encountered the same problem.
The USB-Blaster II does not work out of the box. By the way, I have also obtained a USB-Blaster III cable, which exhibits the same behavior. It is not usable at all.
What steps can we take next to resolve this problem?
