USB Blaster II locks up after non-volatile key programming
Hi, I have similar issue but on 21.1 quartus prime where i try to program non-volatile key on DE10 nano board, that has cyclone V.
I can program volatile key but not non-volatile key.
I am getting below error....
Info: Command: quartus_pgm -c 1 -k -m JTAG -o "p;C:\MyQuartusExp\output_files\IntroEx.ekp@2"
Info (213045): Using programming cable "DE-SoC [USB-1]"
Info (213011): Using programming file C:/MyQuartusExp/output_files/IntroEx.ekp with checksum 0x00001184 for device 5CSEBA6@2
Info (209060): Started Programmer operation at Thu Aug 15 16:37:39 2024
Info (209005): Programming status: Current hardware doesn't support security key programming
Error (209012): Operation failed
Info (209061): Ended Programmer operation at Thu Aug 15 16:37:39 2024
Error: Quartus Prime Programmer was unsuccessful. 1 error, 0 warnings
Error: Peak virtual memory: 2101595 megabytes
Error: Processing ended: Thu Aug 15 16:37:39 2024
Error: Elapsed time: 00:00:04
Error: Total CPU time (on all processors): 00:00:00
Have been stuck with this problem, any hints would help.
