11 years agoUSB Blaster II locks up after non-volatile key programming
Hi all, I am programming non-volatile design security key to Cyclone V using USB Blaster II. I am using Quartus 14.1 on Windows 7 64bit and USB Blaster II driver that comes with 14.1. I kn...
11 years agoFYI, Altera has been working on this problem for several weeks. If anyone else is facing the issue, please raise a support ticket so maybe they'll eventually fix it. I have also seen the USB Blaster II to go slow sometimes even without trying to program the key, this might be related.
Meanwhile I have been using the devcon.exe workaround, I was able to give Teststand enough privileges that it can use it automatically.
