USB BLASTER II Driver Windows 10
- 5 years ago
There is a patch available. Please follow the KDB article below:
Why does the Intel® FPGA Download Cables drivers installation fail on Windows* operating system?
Regards.
Regards.
- Gigiz5 years ago
Ok thanks, it's running.
Gigi
- tpalomaki5 years ago
so you did not bother updating the lite 20.1.1? the standard fix with much pain will work
- bobcladic5 years ago
Yes! I have the same question. the Quartus lite version cannot use these two patches.
- sidd4 years ago
Check following link for lite version
Why does the Intel® FPGA Download Cable II driver installation...
just have to replace two files from updated drivers provided at link above.
It works
- sidd4 years ago
It works
- MTwist5 years ago
I am unable to find the directory that the stdp patch wants with a Quartus Lite installation.
I see that others have the same problem. What is the solution for that? Tough noogies?
- MTwist5 years ago
Well, here is what I've managed to figure out. It probably is tough noogies on Quartus Prime Lite. The workaround is this: (I'm on Win 10 Pro)
Download the Quartus Prime Pro standalone programmer and tools, V21.2. This is a free utility that will install a proper signed driver. After installing the programmer, launch the Driver Installer on the last page of the wizard. After that is installed (But wait, there's more!), close the Pro programmer app. Plug in the USB-Blaster II cable. Go to the Windows device manager (right-click on start button), look for "other hardware". There are two devices, the console interface and the JTAG interface, Both labeled Blaster-II. Right click on each and "update driver". Select "Browse for Driver..." Navigate to C:\intelFPGA_pro\21.2\qprogrammer\quartus\drivers\usb-blaster-ii and let 'er rip. Two devices, two updates. Voila. Nevermind the patches. Return to Quartus Prime Lite and launch the programmer tool. Select "Hardware Setup" and you should find the USB-Blaster II device on the hardware selection pulldown. You're all set.
- Sekhar4 years ago
Hello Team,
I am not find any solution from the link..
