15 years ago
USB Blaster does not work on Quartus II
I installed the driver correctly from the altera installation folder and on the device manager everything is ok (Win XP 32bit). If I run the Programmer on Quartus II 10.0 there is no USB Blaster. If I press "Add Hardware" following error occurs:
attempted to access jtag server -- internal error code 82 occurred
Than I tried following:
Manually restart the JTAG Server service by locating the jtagserver.exe program and at a command prompt for that directory, type jtagserver --install <Enter>
And I got this in the command prompt:
error 1073 installing service
On a other Computer the USB Blaster works fine (Quartus II 9.1). I reinstalled Quartus II but without any success.
What can I do?
Thanks!
EDIT: I naturally deactivated the firewall
