You moved the data assignment before the begin. You aren't allowed to do that, all the signal or variables assignments must be done after "begin".
But why are you using a "data" signal to begin with? You can directly compare A and B in your process. Besides, using the intermediary "data" signal in your process while it isn't on the sensitivity list will give you unwanted behaviour in a VHDL simulator.
And I agree with mmTsuchi, using ieee_logic_unsigned can be dangerous, you should stick to numeric_std instead and use its "unsigned" and "signed" types instead of std_logic_vector when they represent numbers.
