Thank u so much for your time. I had done exactly what u said still gave error (attached doc), but i still like to link "data" to "B" because B is what my test bench recognized.
--- Quote Start ---
hi,
Delete the line "B = data;" : no sense and must generate an error because B is an INput.
Be carefull : A and B are std_logic_vectors. SIGNED or UNSIGNED, we don't know, BUT you specify
use std.ieee_logic_unsigned.all. as a result a and b are treated as unsigned. I belive that IEEE.STD_LOGIC_UNSIGNED is NOT a IEEE standard.
You want to compare with "data", then you should have written "IF A < data THEN ..."
--- Quote End ---
