11 years ago
[URGENT] Need helps !!
Hi. I need to solve my problem in this case.
Please pardon my variable name because it is in Indonesian.
And i want to ask, how about the syntax about If inside If, different than else if.
Here is my code :
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_arith.all;
USE ieee.std_logic_unsigned.all;
USE ieee.numeric_std.all;
ENTITY Traffic IS
PORT (
        clock : INSTD_LOGIC;
        mode : INSTD_LOGIC;
        darurat : INSTD_LOGIC;
        M_US : OUTSTD_LOGIC;
        M_BT : OUTSTD_LOGIC;
        K_US : OUTSTD_LOGIC;
        K_BT : OUTSTD_LOGIC;
        H_US : OUTSTD_LOGIC;
        H_BT : OUTSTD_LOGIC
END Traffic;
ARCHITECTURE behavioral OF Traffic IS
    TYPE executionStage IS (s1,s2,s3,s4);
    SIGNAL currentstate : executionStage := s1;
BEGIN
    PROCESS(clock,mode,darurat)
    variable ctime : integer := 0;
    variable clk : integer := 0;
    variable wkt_darurat : integer := 0;
    constant div : integer := 2;
    BEGIN
    if (clk'event and clk='1') then
        CASE currentstate IS
        when s1 =>
        if (clk < div ) then
            clk := clk+1;
        else
            ctime := ctime + 1;
            clk := 0;
        end if;
        if (darurat = 0) then
            M_US <= '1';
            M_BT <= '0';
            K_US <= '0';
            K_BT <= '0';
            H_US <= '0';
            H_BT <= '1';
        end if;
        if (mode = '0') and (ctime = 8) and (darurat= '0') then
            currentstate <= s2;
            ctime := 0;
        else if (mode = '1') and (ctime = 4) and (darurat = '0') then
            currentstate <= s2;
            ctime := 0;
        else if (darurat = '1') then
                if (ctime mod 2,0) and (wkt_darurat < 4) then
                    M_US <= '0';
                    M_BT <= '0';
                    K_US <= '1';
                    K_BT <= '1';
                    H_US <= '0';
                    H_BT <= '0';
                    wkt_darurat := wkt_darurat + 1;
                else if (ctime mod 2,1) and (wkt_darurat < 4) then
                    M_US <= '0';
                    M_BT <= '0';
                    K_US <= '0';
                    K_BT <= '0';
                    H_US <= '0';
                    H_BT <= '0';
                else
                    wkt_darurat := 0;
                end if;
            currentstate <= s1;
        end if;
        when s2 =>
            clk := clk+1;
        else
            ctime := ctime + 1;
            clk := 0;
        end if;
        if (darurat = '0') then
            M_US <= '1';
            M_BT <= '0';
            K_US <= '0';
            K_BT <= '1';
            H_US <= '0';
            H_BT <= '0';
        end if;
        if (mode = '0') and (ctime = 2) and (darurat = '0') then
            currentstate <= s3;
            ctime := 0;
        else if (mode = '1') and (ctime = 1) and (darurat = '0') then
            currentstate <= s3;
            ctime := 0;
                M_US <= '0';
                M_BT <= '0';
                K_US <= '1';
                K_BT <= '1';
                H_US <= '0';
                H_BT <= '0';
                K_BT <= '0';
                K_US <= '0';
            else
                wkt_darurat := 0;
            end if;
            currentstate <= s2;
        end if;
        when s3 =>
            clk := clk+1;
        else
            ctime := ctime + 1;
            clk := 0;
        end if;
        M_US <= '0';
        M_BT <= '1';
        K_US <= '0';
        K_BT <= '0';
        H_US <= '1';
        H_BT <= '0';
        if (mode = '0') and (ctime = 8) and (darurat = '0') then
            currentstate <= s4;
            ctime := 0;
            currentstate <= s4;
            ctime := 0;
                K_BT <= '1';
                K_US <= '1';
                K_BT <= '0';
                K_US <= '0';
            else
                wkt_darurat := 0;
            end if;
        else
            currentstate <= s3;
        end if;
        when s4 =>
            clk := clk+1;
        else
            ctime := ctime + 1;
            clk := 0;
        end if;
        M_US <= '0';
        M_BT <= '1';
        K_US <= '1';
        K_BT <= '0';
        H_US <= '0';
        H_BT <= '0';
            currentstate <= s1;
            ctime := 0;
            currentstate <= s1;
            ctime := 0;
                K_BT <= '1';
                K_US <= '1';
                K_BT <= '0';
                K_US <= '0';
            else
                wkt_darurat := 0;
            end if;
        else
            currentstate <= s4;
        end if;
        END CASE;
    end if;
    END PROCESS;
end behavioral;
and this is the error i got :
Error (10500): VHDL syntax error at traffic.vhd(81) near text "when";  expecting "end", or "(", or an identifier ("when" is a reserved keyword), or a sequential statement
Error (10500): VHDL syntax error at traffic.vhd(122) near text "when";  expecting "end", or "(", or an identifier ("when" is a reserved keyword), or a sequential statement
Error (10500): VHDL syntax error at traffic.vhd(154) near text "else";  expecting "end", or "(", or an identifier ("else" is a reserved keyword), or a sequential statement
Error (10500): VHDL syntax error at traffic.vhd(158) near text "when";  expecting "end", or "(", or an identifier ("when" is a reserved keyword), or a sequential statement
Error (10500): VHDL syntax error at traffic.vhd(190) near text "else";  expecting "end", or "(", or an identifier ("else" is a reserved keyword), or a sequential statement
Error (10500): VHDL syntax error at traffic.vhd(194) near text "CASE";  expecting "if"
Error (10500): VHDL syntax error at traffic.vhd(197) near text "PROCESS";  expecting "if"
I've made a difference between s1,s2 and s3,s4.
I removed the else in s1 and s2 because it removes the error i got.
But when errors still remains.
Thanks for your help.
