8 years ago
Upgrade Quartus 17.0 to Quartus 18.0 issue
Hi everyone,
I have a problem with Quartus 18.0 standard version.
If I compile my project on Quartus 17.0 it needs about 75 minutes, on the other hand after the upgrade to 18.0 standard version it needs 225 minutes, it's a huge difference.
The settings of the quartus 17.0 and 18.0 are the same, both FPGA codes works. However, I don't understand why.
Some advices?
Just tried to delete the database nothing's changed.
    How many processor cores is Quartus using in 17.0 and 18.0 respectively?
    Hi mhavu,
    thank you for the answer.
    Both 17.0 and 18.0 are using all the cores. In our case 6 cores.
    Is there a certain part of the compilation process that takes more time on 18.0, or is every part proportionally slower?
    What device are you compiling for and how full is the device?
    Hi sstrell,
    the device is an Arria V and we are using 70% of the device's resources.
    Based on above conversation if both database & processor cores taken care, It may be an issue.
    Can you share your design? If cannot share it on the forum you can file a service request.
    Anand Raj Shankar
    Hi Anand,
    I'm trying to file a service request but I can't. Everytime I submit the request appearing the message "We are unable to complete the transaction. Please try again later"
    Suggestions.....
