17 years ago --- Quote Start --- This may be unconventional, but I located the offending file in \megafunctions directory, and renamed it to sld_hub.old. --- Quote End --- You gonna miss this file, if you once have any virtual JTAG IP in your design, may be SignalTap, Source&Probe, In System Memory Editor or such. I don't think, that you have an old file in your Quartus V8.1 megafunctions directory, if so, it would have a different file date than the other sld_xxx.vhd files. I rather guess, Steve_dB was correct with his suggestion.
