syam
5 years agoUpgrade error from Quartus 12.1 to Quartus 13.1
We have a legacy target design done using SOPC builder Quartus 12.1. When we try to upgrade it to QSYS in Quartus 13.1 we are getting an error (pic attached).
Is there any way we can get the Quart...
KhaiChein_Y_Intel
5 years agoHi,
The Quartus II v12.1 has been discontinued. You have to upgrade the design to the latest software version.
The error indicates that the component is not available in the library. Since the component mentioned is not compatible, you have to add the component from IP Catalog and reconnect.
KhaiY
syam
5 years agoThanks. We cannot open the SOPC design. So how will we delete and reconnect the incompatible component ?
The upgrade process because of the error (screenshot shared earlier) doesn't load any target design even as an incomplete design. Kindly help.
