11 years agoUpdateDriverForPlugAndPlayDevices
I am trying to install DE5-net board from Terasic on a machine having Intel Core i5-3470 CPU running Windows 7 Professional Service Pack 1. I can flash the device (USB blaster driver is working) b...
9 years agoI encounter the same error. Have you solved it? Could you give me some advice?
Thanks. --- Quote Start --- Hi David, Sorry, I didnt see your reply earlier. I was in contact with Terasic support to solve this problem. But it is still not resolved after over a month of communication. The customer support said that it is a problem with by PCIe slot. So, I tried the same card (DE5-net) on another computer and got same error of UpdateDriverForPlugAndPlayDevices using the aocl install command. I have also tried installing it using the device manager, on both the systems (There is a PCI device shown in devices with exclamation mark). On first system the error was "The Install class is not present or invalid" and on the second system, the error is "The required section is not found in the INF". Is it possible that I have got a bad DE5-net card? Thanks --- Quote End ---
