11 years agoUpdateDriverForPlugAndPlayDevices
I am trying to install DE5-net board from Terasic on a machine having Intel Core i5-3470 CPU running Windows 7 Professional Service Pack 1. I can flash the device (USB blaster driver is working) b...
11 years agoHi there,
We did a little research and found a thread that might be related to your case. Please refer to http://www.postseek.com/meta/68a0c8c5bab42d3bed9a95beef3dc341. Meanwhile please follow the steps below, assuming you've installed windriver successfully and you are now ready to install the board driver in aocl. 1. Download the .sof file for OpenCL or execute the command aocl flash 2. Reboot your PC 3. Right click on My Computer -> Property -> Device Manager 4. You should see a PCI device with exclamation mark, assuming it can be detected by Windows 5. Right click on it and select Update Driver 6. Point the directory of driver to de5net\windows64\driver\acl_boards.inf and see if it works Please give it a try and let us know how it goes. Thanks, David from Terasic
