12 years ago --- Quote Start --- When i want to Update Memory Initialization File .. Processing -> Update Memory Initialization File this error always appears: Found no memory initialization files to process ... with quartusII 9.1 sp1 ... --- Quote End --- I observed that if you're using "altsyncram" provided by Altera you have to put the correct path in the right place: Example: altsyncram_component : altsyncram GENERIC MAP ( ... init_file => "Memory/memory_file.mif", ... Remember this: the path should consider that the project directory is the "root directory". So if your ".mif" is in "c:\Altera\Project\Memory\memory_file.mif" and your project directory is in c:\Altera\Project, so above is the right way to describe. So, fix it and do this again (Processing -> Update Memory Initialization File).
