8 years agoUp-to-date example design
Hi all,
I try to synthesize and use design example from Intel. https://www.altera.com/support/support-resources/design-examples/design-software/opencl/library-design-example.html Does anybody have managed to compile the example 2 for linux with the last version 17.1 ? I could not make it. The errors seem to come from the IP that are not compatible from the 2 version of the tool (and other stuff). Does anyone has an version for the 17.1 tool ? Thanks in advance ! b2 Replies
Have you checked it with version 16.1? Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) - Altera_Forum
Hi Anand,
I did not checked with version 16.1. I'm rather confident it's OK with this one because it is the officially supported version. I'm more interested in a solution for upgrading the design to make it work with 17.1 version (some design are working when auto-upgraded via Quartus).
