I've had a little play and this is how I would do an up down counter:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity people_count is
generic
COUNTER_WIDTH: integer := 8
port (
in_clk : in std_logic;
in_reset : in std_logic;
in_incCount : in std_logic;
in_decCount : in std_logic;
out_count : out std_logic_vector(COUNTER_WIDTH-1 downto 0)
end entity people_count;
architecture arch_people_count of people_count is
signal count: unsigned(COUNTER_WIDTH-1 downto 0);
signal count_up: std_logic;
signal count_down: std_logic;
begin
count_up <= '1' when in_incCount ='1' and in_decCount = '0' else '0';
count_down <= '1' when in_incCount ='0' and in_decCount = '1' else '0';
process(in_clk, in_reset)
begin
if in_reset = '1' then
count <= (others => '0');
elsif rising_edge(in_clk) then
if (count_up = '1') then
count <= count + 1;
elsif (count_down = '1') then
count <= count - 1;
end if;
end if;
end process;
out_count <= std_logic_vector(count);
end architecture arch_people_count;
but you would need to synchronize the inputs, debounce the switch and put an edge detector on the input!
have fun :)
geobyjmh
http://geobyjmhembeddedengineer.blogspot.co.uk/
