9 years agoup counter needs fixing - confused . simple question
Hi, this is a simple counter with asynch pre-set(not wired in diagram), enable, load and synch add +1. i can't figure the trick to get rid of one extra mux column and use the FF enable (where red arr...
9 years agosomething like this, though i tried different combinations for the 'if' condition, as in in different places or using 'elseif', yet still same result...
process(clk, rst) variable cnt : unsigned(3 downto 0) begin if rst = '0' then cnt := (others => '1'); elsif rising_edge(clk) then if load = '1' then cnt := new_data; end if; if ena = '1' then cnt := cnt +1; end if; end if; cnt_out <= cnt; end process;
