University VWF won't work
Could you shared the project .qar file so I could try to duplicate the issue from my side?
You may try to restore the simulation setting to default, in the vwf.
I have a feeling this might be a bad installation.
Could you try with a different machine and see if the issue occurs.
Richard Tan
- engtjm3 years ago
Hi Richard,
I have the same issue, I have just installed the v21.1 Lite version and this is my first attempt at simulation. The transcript from the simulator is below, and my archive file is attached.
Thank you in anticipation for your help.
Tim Mulroy
Determining the location of the ModelSim executable...
Using: C:/intelFPGA_lite/21.1/questa_fse/win64
To specify a ModelSim executable directory, select: Tools -> Options -> EDA Tool Options
Note: if both Questa Intel FPGA Edition and ModelSim executables are available, Questa Intel FPGA Edition will be used.**** Generating the ModelSim Testbench ****
quartus_eda --gen_testbench --tool=modelsim_oem --format=verilog --write_settings_files=off decoder2 -c decoder2 --vector_source="C:/Users/engtj/Quartus/decoder2/Waveform.vwf" --testbench_file="C:/Users/engtj/Quartus/decoder2/simulation/qsim/Waveform.vwf.vt"
Info: *******************************************************************
Info: Running Quartus Prime EDA Netlist Writer
Info: Version 21.1.1 Build 850 06/23/2022 SJ Lite Edition
Info: Copyright (C) 2022 Intel Corporation. All rights reserved.
Info: Your use of Intel Corporation's design tools, logic functions
Info: and other software and tools, and any partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Intel Program License
Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
Info: the Intel FPGA IP License Agreement, or other applicable license
Info: agreement, including, without limitation, that your use is for
Info: the sole purpose of programming logic devices manufactured by
Info: Intel and sold by Intel or its authorized distributors. Please
Info: refer to the applicable agreement for further details, at
Info: https://fpgasoftware.intel.com/eula.
Info: Processing started: Tue Jan 24 15:06:29 2023
Info: Command: quartus_eda --gen_testbench --tool=modelsim_oem --format=verilog --write_settings_files=off decoder2 -c decoder2 --vector_source=C:/Users/engtj/Quartus/decoder2/Waveform.vwf --testbench_file=C:/Users/engtj/Quartus/decoder2/simulation/qsim/Waveform.vwf.vt
Warning (18236): Number of processors has not been specified which may cause overloading on shared machines. Set the global assignment NUM_PARALLEL_PROCESSORS in your QSF to an appropriate value for best performance.
Completed successfully.
**** Generating the timing simulation netlist ****
quartus_eda --write_settings_files=off --simulation --functional=off --flatten_buses=off --timescale=1ps --tool=modelsim_oem --format=verilog --output_directory="C:/Users/engtj/Quartus/decoder2/simulation/qsim/" decoder2 -c decoder2
Info: Processing started: Tue Jan 24 15:06:30 2023
Info: Command: quartus_eda --write_settings_files=off --simulation=on --functional=off --flatten_buses=off --timescale=1ps --tool=modelsim_oem --format=verilog --output_directory=C:/Users/engtj/Quartus/decoder2/simulation/qsim/ decoder2 -c decoder2
Warning (10905): Generated the EDA functional simulation netlist because it is the only supported netlist type for this device.
Info (204019): Generated file decoder2.vo in folder "C:/Users/engtj/Quartus/decoder2/simulation/qsim//" for EDA simulation tool
Info: Quartus Prime EDA Netlist Writer was successful. 0 errors, 2 warnings
Info: Peak virtual memory: 4657 megabytes
Info: Processing ended: Tue Jan 24 15:06:30 2023
Info: Elapsed time: 00:00:00
Info: Total CPU time (on all processors): 00:00:01
**** Generating the ModelSim .do script ****
C:/Users/engtj/Quartus/decoder2/simulation/qsim/decoder2.do generated.
**** Running the ModelSim simulation ****
C:/intelFPGA_lite/21.1/questa_fse/win64/vsim -c -do decoder2.do
Error.
