14 years agoHi,
I'm working on a DDR3 design with UNIPhy on Stratix iv. These pins you must assign to any bank with the same I/O voltage as the memory interface signals (see External Memory Interface Handbook Volume 5, Section II. UniPHY Design Tutorials, page 2-2). Some deticated pins ar not usable for OCT, see pin connection guide for the device you are using. (i.e. the CLK[1,3,8,10]p pins in case of stratix iv ). The attached images show the toplevel and pin connections in an example design based on the Stratix iv GX Devkit wich I'am using actually. Jens
