13 years agoUnderstanding how tool treats HDL code- Verilog blocking and non-blocking assignment
Hello, I am learning Verilog and trying to understand how particular code is synthesized later on.
I understand that blocking statements has a procedural flow as mentioned bellow (ref: asic-world). 1 will execute first, 2 after 1 and 3 at the end. 1 a = b; 2 out_d = 0; 3 {carry, sum} = in + sum_in; If a bunch of blocking statement are independent of each other (no data dependency) then are they synthesized as a parallel combinational blocks ? As an example the following series of codes don't can be actually execute in parallel in hardware. 1 a[0] = b[0] | b[1] 2 c[0] = b[2] | b[3] 3 d[0] = b[4] | b[5] Thanks in advance!
