12 years agoBut it is strange still. When i use basic constraints from:
http://www.altera.com/support/examples/timequest/exm-tq-basic-sdc-template.html ============================================= # Constrain clock port clk with a 10-ns requirement create_clock -name {TS_clk} -period 10 [get_ports {clk}] # Automatically apply a generate clock on the output of phase-locked loops (PLLs) # derive_pll_clocks # This command can be safely left in the SDC even if no PLLs exist in the design derive_clock_uncertainty # Constrain the input I/O path set_input_delay -clock {TS_clk} -max 3 [all_inputs] set_input_delay -clock {TS_clk} -min 2 [all_inputs] # Constrain the output I/O path set_output_delay -clock {TS_clk} 2 [all_outputs] ======================================= I am not able to increase fmax up to 120MHz. But when i dont use constrains for input output, i achieve nearly 200MHz. You can see my 2 designs. The differences are only in sdc file .... and the differences of fmax is massive. How it is possible ? How can i increase fmax, when i use constrains to all inputs and outputs ? Thank you. Jan
