Unconstrained I/O when using design partitions
Hello I am doing late floorplanning and have started with setting up design partitions.
To start I have a single partition set to post-fit.
My issue is that upon compilation, I get a ton of unconstrained i/o from the new partition. What is the correct way to constrain these i/o? I'm only familiar with constraining top level i/o
- sstrell
Can you explain what is complete in your design? When you say I/O, those are usually top-level, so it's not clear what you mean by unconstrained I/O that are not top-level.
- VCham
Before attempting partitioning, my design was fully complete. There were zero unconstrained I/O. Timing was being met.
When I added a design partition, the TimeQuest Analyzer reported 46 unconstrained output ports. Looking at the signals they are just an avalon memory mapped address bus that is an input to the partition. I am not sure why it's being called out as unconstrained.
- AqidAyman_Altera
Hi Valentina,
What device is you using and which edition of Quartus?
Aqid
- VCham
Quartus II Standard 17.0.2
Cyclone V
- sstrell
So your design was complete and you simply set part of it as a design partition, recompiled, and got this? Can you show your design partition settings/assignments? For some reason, the connections from your design partition to the root partition of your design are missing. Simply setting an entity as a design partition should not cause this to happen. You're not using virtual pin assignments, are you?
- VCham
Since my last post I've tried the autopartitioner to help with different issues. But I'm still getting the same unconstrained paths.
These are the current partition settings. I am not using any virtual pins.
- AqidAyman_Altera
Can you try the steps to size and and place regions after compilation as in Best Practices for Incremental Compilation Partitions and Floorplan Assignments page 15-45?
- AqidAyman_Altera
Hi Valentina,
Any updates on the status from your side? Does it resolve your issue?
Aqid
- AqidAyman_Altera
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
