VCham
4 years agoUnconstrained I/O when using design partitions
Hello I am doing late floorplanning and have started with setting up design partitions.
To start I have a single partition set to post-fit.
My issue is that upon compilation, I get a ton of unc...
sstrell
4 years agoSo your design was complete and you simply set part of it as a design partition, recompiled, and got this? Can you show your design partition settings/assignments? For some reason, the connections from your design partition to the root partition of your design are missing. Simply setting an entity as a design partition should not cause this to happen. You're not using virtual pin assignments, are you?
VCham
4 years agoSince my last post I've tried the autopartitioner to help with different issues. But I'm still getting the same unconstrained paths.
These are the current partition settings. I am not using any virtual pins.
