13 years ago
Unconstrained Clocks
When I view the TimeQuest Timing Analyzer - Unconstrained Paths Summary, 4 Unconstrained Clocks appear. The 4 unconstrained nets should not be clocks, but they are being flagged by the tool. How do I remove these nets as appearing as clocks?
    You're using them to drive registers' clock port.
    Ie, you have something like it.
    process(some_signal) begin
    if rising_edge(some_signal) then
    end if;
    end process;
    Most of the time, you'll want to change your design not no do that.
    I've never seen it report a clock that wasn't being used as one. If I don't know what it's driving, I do a quick:
    create_clock -period 1.0 -name test [get_keepers {}]
    (It may be get_ports, or something like that). Then just report_timing to that new clock.
    The report is there to help you. There is nothing in .sdc to say, I'm not a clock, you just choose not to constrain it. The Unconstrained Paths report is outside of .sdc constraints, and really just trying to help you identify possible mistakes. I would ignore it if it is a clock and you just don't want to constrain it.
    (A final option is to put a clock constraint on it that's 1000.0 ns, then do:
    set_false_path -to [get_clocks test_clk]
    set_false_path -from [get_clocks test_clk]
    It should get rid of the info message since it's constrained, and it wont' be analyzed.
    You can also use "derive_clocks -period 10.0" to create the clock for you, and then just report timing to the clock that is created that is driving the clock pin in question.
