SATC
6 years agoUnavailable to Create CvP File at Convert Programming File at Intel Quartus Prime Pro 19.3 version
I'm using the Intel® Cyclone® 10 GX CvP Initialization over PCI Express User, so i'm set the ProgrammingFile Type as JTAG Indirect Configuration File (.jic), but when i choose the configuration devic...
- 6 years ago
Do you enable the CvP in your PCIe IP setting? Could you share with me your sof file?
JohnT_Altera
6 years agoHi,
May I know when you compile your project, is the CvP Initialization is enabled?
- SATC6 years ago
yes, it is.
