FabianL's avatar
FabianL
9 months ago
Unable to use Avalon-MM master verification BFM in Questa sim
I have a bug similar to the one reported here :
https://community.intel.com/t5/Intel-Quartus-Prime-Software/Avalon-Verification-IP-example-avlmm-1x1-vhdl-not-working-in/m-p/1516388
or here
Unable to use Avalon-MM master verification BFM in Questa sim - Intel Community
The Problem still exists in Questa 25.1 when using the "-suppress 12110" option it gives this warning:
# ** Error (suppressible): (vsim-12110) All optimizations are disabled because the -novopt option is in effect. This will cause your simulation to run very slowly. If you are using this switch to preserve visibility for Debug or PLI features, please see the User's Manual section on Preserving Object Visibility with vopt. -novopt option is now deprecated and will be removed in future releases.
Without using the "-suppress 12110" and the "-novopt" option all the Avalon BFM models won't work in Questa. Everything is running fine with modelsim.
Are there any plans on fixing this issue?
best regards
Fabian
