Abhishek_C_Intel
8 years agoUnable to synthesis design if defines are included in seperate file
I am synthesizing my design in quartus prime. The FPGA used in our design is stratix 10. I am synthesis a synopsys designware IP. The IP has separate files for defines and these defines were saved as...
Abhishek_C_Intel
8 years agoHi,
Thank you for your response.
My question is I am having two files which contains `define and the other files which are using it. In my file list I have maintained the order of files so that files containing `defines are read first. Still quartus is generating an error. I am not facing this issue with any other synthesis tool like Xilinx vivado or synplifypro etc.
I checked the switches/options for set_global_assignment and found that we can use VERILOG_INCLUDE_FILE switch/option. Yet the tool is generating the error.
I think this issue is only related to quartus. Is there a way to avoid manually editing the files and use options/switches available with set_gobal_assignment.
Thanks & Regards
Abhishek
