13 years agoUnable to run RTL Simulation
Hello, I am trying to do an RTL simulation but I keep getting this error message:
Info: Start Nativelink Simulation process executing command line: ip-make-simscript --nativelink-mode --output-directory=UxSRADAR_iputf_input --spd=D:/Joes/Projects/Working/UxRADAR/Altera/Complete_Design/UxS_RADAR/pll2.spd --spd=D:/Joes/Projects/Working/UxRADAR/Altera/Complete_Design/UxS_RADAR/pll1.spd --spd=D:/Joes/Projects/Working/UxRADAR/Altera/Complete_Design/UxS_RADAR/pll3.spd Error: You did not generate the simulation model files or you generated the IP file using an older version of MegaCore which is not supported by RTL NativeLink Simulation Error: Regenerate the IP and simulation model files using the latest version of MegaCore for RTL NativeLink Simulation flow to function correctly Error: NativeLink simulation flow was NOT successful ================The following additional information is provided to help identify the cause of error while running nativelink scripts================= Nativelink TCL script failed with errorCode: NONE Nativelink TCL script failed with errorInfo: Regenerate the IP and simulation model files using the latest version of MegaCore for RTL NativeLink Simulation flow to function correctly (procedure "get_ip_info" line 1) invoked from within "get_ip_info $full_file_name" (procedure "run_eda_simulation_tool" line 195) invoked from within "run_eda_simulation_tool eda_opts_hash" I have regenerated the PLLs that I have in my design but keep getting this error message within Quartus after I click the RTL button. Can anyone help me? Thanks, joe2 Replies
Did you try regenerating your IP so that the Quartus can use the up-to-date simulation files?
Any ideas? I ran into the similar errors although I already re-generating the up-to-date simulation files.
