Unable to run Intel HLS examples
Hi all,
I installed the Quartus Prime Pro version 17.1 with HLS compiler and Microsoft Visual Studio 2015 Professional. I followed the steps given in the HLS compiler getting started guide. When I ran the following command
init_hls.bat
It was complaining for the Visual Studio path and I have setup manually.
When I ran the examples such as QRD or Counter, I get the following errors as
string.h not found or queue not found
which means that it is unable to locate the standard libraries.
I would like to know whether the Visual Studio should be in specific path for the HLS to use ?
How does the HLS finds these standard libraries?
Kindly help me in resolving these issues.
Thanks in advance!
Nivetha
- Abe
Which version of Visual Studio have you installed.. have you installed the one supported by Intel Quartus tools aka 2010 version?
- NSuku1
Hi!
I mentioned that I have installed Quartus Prime Pro 17.1 with Microsoft Visual Studio 2015 which is mentioned by Intel.
- Abe
Can you try running the init_hls.bat file in an elevated command prompt (one with Administrator privileges) and check if it works.
- NSuku1
Hi! Thanks for helping me in resolving this issue. I will try whether it works with the admin rights. But, I am afraid that I may not be able to get the admin rights always to use the tools.
Nivetha
