10 years agoUnable to run DSE II fails with Error: [Errno 11004] getaddrinfo failed
I am fixing the batch file used to run the builds on multiple FPGAs and to do so I tried to first see the differences in the new DSE GUI and modify the script accordingly. I am unable to for it compi...
9 years agoWhile I can't speak for anybody else, I had the same problem, and adding the localhost address (127.0.0.1) as recommended above, fixed the problem. Is this in the documentation? If not, shouldn't it be?
