SS5
8 years agoUnable to read the data from AVALON FIFO MEMORY under on-chip memory
I want to write 32-bit data into FIFO and read that data from FIFO. [FIFO configuration :Aalon-MM write slave to Avalon-MM read slave.] I have tried the below design but data is not in proper seque...
Daixiwen
8 years agoYou can't write on each clock cycle. You should change your design to check whether the fifo is full or not and only write the value (and increment the counter) when the fifo is not full.
