SS5
8 years agoUnable to read the data from AVALON FIFO MEMORY under on-chip memory
I want to write 32-bit data into FIFO and read that data from FIFO. [FIFO configuration :Aalon-MM write slave to Avalon-MM read slave.] I have tried the below design but data is not in proper seque...
KennyT_altera
8 years agoHi,
You can try out the example here https://www.intel.co.jp/content/dam/altera-www/global/ja_JP/pdfs/literature/ug/ug_nios2_flash_programmer.pdf to see if you able read the correct memory.
