10 years agoUnable to program EPCS64 via SFL
Hi all, I am attempting to reprogram a previously loaded EPCS64 through my Cyclone III LS. The EPCS64 were preprogrammed with a test load before board installation.
I am now attempting to update this load with a new .jic. I have used this same setup and circuit on a previous board with no problems. I have also used these USB Byteblasters before. I reset the FPGA back to factory default, and once I switch to Quartus and begin to program, I get this: Info (209017): Device 1 contains JTAG ID code 0x027010DD Info (209007): Configuration succeeded -- 1 device(s) configured Error (209062): Flash Loader IP not loaded on device 1 Error (209012): Operation failed This happens most of the time. Occasionally the SFL programming will succeed, but I then get this error: Info (209017): Device 1 contains JTAG ID code 0x027010DD Info (209007): Configuration succeeded -- 1 device(s) configured Info (209018): Device 1 silicon ID is 0x16 Info (209044): Erasing ASP configuration device(s) Error (209012): Operation failed Info (209061): Ended Programmer operation at Thu Jan 07 09:29:29 2016 This is my first time powering up and using these boards, but my voltage levels look correct on all my rails. The recommended resistor values are correct, and as I mentioned I have used this exact same circuit on a previous design without issue. Any help would be much appreciated!1 Reply
EPCS64 block protection bits may have been set. Try Quartus programmer option "Unprotect EPCS devices" under tools/options.
