Unable to program de1 soc device, compilation fine with no errors
Linux Mint 21.3 Cinnamon / Cinnamon Version 6.0.4 / Linux Kernel 5.15.0-122-generic / Processor Intel© Core™ i3-4030U CPU @ 1.90GHz × 2 / Memory 3.7 GiB / Graphics Card Intel Corporation Haswell-ULT Integrated Graphics Controller241.1 GB / Display Driver X11
Was having the exact same troubles using this linux OS with programmer not working. I lost track of the multiple lateral, forward, and backward steps to get this to work, but I ultimately did using the same steps as above,,, except 1 additional at the onset,,,, see below...
1. Problem1- programmer not working.
1.5. Solution1- reinstalled the free light version. I had the other and it was not recognizing the USB A to B data cable.
2. Solution1- I reconfigured the switches on the bottom of the fpga board: Per User Manual, 3.1 Settings of FPGA Configuration Mode- "If developers wish to reconfigure FPGA from an application software running on Linux, the MSEL[4:0] needs to be set to 01010 before the programming process begins".
3. Solution1- Followed the same previous posted guide. Worked fine,,, fiNAlleee :). Now to create stuff...
