NMani1
7 years agoUnable to generate example design Serial Lite 3 streaming Intel Arria 10 FPGA IP using Quartus tools
Greetings, I am using Quartus 18.1 to generate the example design for Serial Lite 3 streaming Intel Arria 10 FPGA IP after configuring the parameters and the preset. The process of generating the ex...
Nathan_R_Intel
Contributor
7 years agoHie Neels,
Good news you identified a temporary workaround. I will be adding this issue to our knowledge database and an update accordingly on when the fix will be incorporated.
Nathan
