NMani1
7 years agoUnable to generate example design Serial Lite 3 streaming Intel Arria 10 FPGA IP using Quartus tools
Greetings, I am using Quartus 18.1 to generate the example design for Serial Lite 3 streaming Intel Arria 10 FPGA IP after configuring the parameters and the preset. The process of generating the ex...
Nathan_R_Intel
Contributor
7 years agoHie,
I have checked with Quartus Prime Pro 18.1. The Example design can be generated if you follow the following steps:
1. Select Preset "Standard Clocking Mode 6 x12.5G" and click "Apply". The Preset is located in window at bottom right of the Serial Lite III Streaming Intel Arria 10 FPGA IP.
2. Change Direction from "Duplex" to "Source".
You will not observe only 2 warning instead of 8 warnings as shown in your attached snapshot.
Nathan
